Dash Cam Install
When I pulled the pillar trim the metal clip popped out of the plastic. I needed to remove the clip and reinstall into the white plastic trim before reinstalling the whole thing. I didn't pull the trim all the way out so I had to feed the wire up thru the bottom before routing it to the top of the headliner.
Fuse box diagram just for your info. Diagram isn't complete and there were other fuses that aren't on the sheet.
