P030085 & P030485
P030085 (misfiring) & P030485 (misfiring cylinder 4) DTCs appeared suddenly. About 10,000 miles ago the cylinder head was replaced because of the exhaust valve problem seen on the M260/264 engines through 2022 model year.
The problem does not appear when the GLA is first started. After about 2 minutes of either driving or idling, the very rough running starts. Although these 2 codes are associated with an exhaust valve failure, the 2 mixture codes are not present. Since the cylinder head was replaced fairly recently, a repeat of that wasn’t expected. Also, when the exhaust valve failed, the engine did not run this rough and did it immediately on start up.
Has anyone seen this misfiring without the cylinder head/exhaust valve failure? If so where was the problem? Spark plugs? Ignition coils? Injectors?
I test drove it before returning it to our driver. It felt like the GLA I drive. She says it feels better than before which may be an indication that something had been going wrong for a while.
