Need help identifying correct headlamp wire for 2018 GLA 250
I purchased a LED emblem kit for my GLA 250 and I want to T-tap the power wire into the main headlamp wire on the front drivers side headlamp. This way the emblem will only turn on when the headlights are on. I've looked online and found some references to older models, but I haven't been able to confirm which wire going into the headlamp assembly is the correct one to use. Does anyone know which wire is the correct power wire for the main headlamp?
Thanks in advance!
