GLA Class (X156) Produced 2013-2020
GLA250 Rear View Camera Works When It Feels Like It
Old Jul 4, 2022 | 09:28 PM
flopper's Avatar
GLA250
My 2017 GLA250 4matic's rear camera started acting up a few weeks ago. Sometimes it works flawlessly, other times not at all, and other times part time.
When it's trying to work but something keeps it from doing so, it makes a noise like there is something wrong mechanically for the camera to lower.
I lowered it using the settings feature and it lowers just fine that way. While I had it down I sprayed some water on it and cleaned it up for the first time. I have not changed anything since purchasing it new back in 2016; the license plate frame is still the one that the dealer had put on.
The camera itself appears to work fine. I wonder if there is a problem when the camera and the camera control module are trying to communicate.
Any ideas?
Old Jul 5, 2022 | 02:05 PM
190Efan's Avatar
1991 190E 2.3
Sounds like something in the lowering mechanism is sticking in some way to prevent the camera from lowering. I would not spray water on anything electronic as the water could short out the electronics. I would try some sort of electronics cleaner and see if that'll help free up the lowering mechanism.
Old Jul 6, 2022 | 08:25 AM
flopper's Avatar
GLA250
Plain water is the recommended way to clean the camera. My first impression was also what you suggest - that the mechanism that lowers the camera is acting up perhaps because o corrosion or dirt - hence the reason I cleaned it. I can't see any corrosion there when I lower the camera using the "settings" option on the navigation screen which operates the camera flawlessly! I believe it may be something to do with the communication between the camera and the camera control module. But I cannot find any information on how to diagnose that. I do have some electric/electronic cleaning spray that I could try spraying the camera with, but when the camera is lowered I cannot see anything electronic to spray, just the camera housing!
Old Jul 6, 2022 | 01:34 PM
190Efan's Avatar
1991 190E 2.3
I would confine any water usage to cleaning the camera screen only. I don't own a GLA. I was just trying to help you out. Maybe try www.glaowners.com. There's more activity there than there is here.
Old Jul 6, 2022 | 06:24 PM
flopper's Avatar
GLA250
I realize you were just trying to help, thanks for that. But, when the camera is lowered all that shows is the camera face (glass and plastic housing).
Old Jul 6, 2022 | 07:28 PM
W205C43PFL's Avatar
If you must use water, make sure it is deionized and wear a glove and use a tool that doesn't conduct, you don't want to make the water by putting your hand in the water.
