Exterior accessories
https://www.ebay.com/itm/Genuine-OE-...oAAOSwlFxfLB59
As far as insulation hood the diagram below. The insulation pad should be able to reduce cabin noise. Item 300 is the insulation blanket and 310 are the clips for it.
https://www.aliexpress.com/item/1005...36498683%22%7D
/QUOTE]
I found this listed as "Hood, Damping" at mbonlineparts.com under GLB35 AMG. PN 182 628 00 00 28. The GLA 250 does not have a hood insulator listed. I don't know if the hoods are similar enough for this to be fit.
/QUOTE]
- SKU:118682000028
- Other Names:Damping, Hood
- Description: Cla250, cla35 amg.
- Condition:New
- Replaces:1186820000
I was really surprised that the GLB did not come with one. If I can't get it, I will probably make one out of the high density aluminum coated rock wool pads available from 3rd parties. I will post results, but it may be quite a while.
Also found a Mercedes Xentry Tip mentioning this exact issue ( https://static.nhtsa.gov/odi/tsbs/20...78717-9999.pdf ), saying the door control modules need to be reprogrammed....
Did anyone else have an issues after installing these OEM logo lights?
I have.mine on GLB and No issues.
I bought the same for my CLA 4 years ago and they still running perfectly.
Here in the UK my dealer says there is no way we can get mudflaps for my 2021 GLB (with 772 AMG trim option) ... he sent me this pic of the available ones which, I agree will not fit
These are my wheelarches...
Front...
and rear...
so I am stumped as to what WILL fit and where I can get them...
https://www.ebay.com/itm/384160363813
The Chinese sellers are selling 2 versions. One seller with your second photo is even telling that it works for GLB 35. I read your post and checked it more... Also I saw in Alibaba that it doesn't fit the rear and some postings in eBay say so. Another eBay seller is selling only front mud flaps for GLB 35 and I bought it. He sent me exactly the same GLB 250 mud flaps as in your second photo including the rears. The fronts fits perfectly to GLB 35 AMG. The rears are off so much... The GLB 35 rear has sloped L shape:
https://www.la.mercedes-benz.com/en/...030125007.jpeg
At least fronts are covered for winter...
35 AMG line has a squarish profile vs. 250 which is round. That should give you an indication which one you need.
GLB 35 AMG
GLB 250
https://www.ebay.com/itm/264821971070
Here in the UK my dealer says there is no way we can get mudflaps for my 2021 GLB (with 772 AMG trim option) ... he sent me this pic of the available ones which, I agree will not fit.
Front...
and rear...
OEM Front Pair Splash Guards Mud Flaps FOR 2019-2021 Mercedes Benz GLB GLB35 AMG
It is the same as GLB 250 model and fits to AMG 35 fronts only...
from ebay in China.... https://www.ebay.co.uk/itm/264821971070 they sent me 4 mudflaps..... the rears do not fit as they are the wrong shape but I am not too bothered, it is the fronts I was after anyway
i think they look pretty good - certainly as good as O.E. fit
just need to find some rears now,.....
from ebay in China.... https://www.ebay.co.uk/itm/264821971070 they sent me 4 mudflaps..... the rears do not fit as they are the wrong shape but I am ot too bothered, it is the fronts I was after anyway
The pictures I posted are for the fronts which, again as I said, do fit perfectly..... I just need to find some that will fit the rear
I see what you mean about the profile (post #62)....where did you get those from ?
These are my rear wheelarches
and these are the mudflaps I received
