Looking for recommendations for the GLB 250 Oil type to use. I've seen mention of 0W20 for this model. In recent years, I've always used the 0W40 Mobil One European blend, but not sure if that is a recommended oil for this model.
On older MBs it was indeed strongly suggested to use Mobil 1 0W40. Actually the instruction was to use oil that complies with MB formulation 229.52. And since Mobil 1 was the only oil with that compliance everybody was using it. I did on my ‘04, ‘05 and ‘06. The GLB does not call for Mobil 1 but it says use a oil that complies with MB 229.51, 229.52, 229.61 or 229.71 suggesting that 229.71 would be the best. Castrol Edge DEXOS below is one of the few available with 229.71 and it comes only in 0W20. At Walmart for $27.
Thanks in advance.
Good question. I was using 0-W40 on my C63 until I switched to 5W-40. My owners manual doesn't specify.
Thanks in advance.
Mobil 1 Euro has 229.3 & 229.5 approvals. It is not appropriate for the GLB250 which is designed for low SPAsh engine oils.
From gafitanu below: … use a oil that complies with MB 229.51, 229.52, 229.61 or 229.71 …
Many moderately priced oils fit one or more of these specs.
When I had my service A done at the dealer they put 6L of 5W30 oil, spec 229.52.
2021 GLB 250 2L gas engine.
I did my own oil and filter change recently and used Mercedes Benz 5w30 oil spec 229.52 (most advanced oil according to MB) I believe the max oil capacity is 5.5L and not 6L.
I am sure you are correct. What I meant is that dealer charged me for 6L.
