GLB35 Check Engine Light on Again
At 2,900 miles the light came on again. They are picking the car up for service next week. I'll post back on the diagnosis, as I've seen others post here with the same check engine light issue on the GLB35.
My dealer mentioned they are very well aware of the issue and have the part stocked up.
Customer states check engine light is on again. Please check and advise. Confirmed customer's concern. Connected SDS and battery charger and performed a short test and found fault code P035496 for the actuation of ignition. Coil 4 has an electrical fault or open circuit. There is an internal component fault. Went through the guided test plan and found Coil 4 faulty. Disconnected the battery and removed and installed the air intake tube and removed and replaced ignition coil 4 and retested. All OK.
