GLB Class (X247) Produced 2020 to Present
Can you leave car running with ac on and doors locked?
Old Jun 29, 2021 | 03:57 PM
Wildchrisk00's Avatar
GLB 250
Can I leave my 2020 Mercedes running with keys in my pocket if I need to run in store and leave ac running and lock car?
Old Jun 30, 2021 | 08:13 AM
Vladimir Livson's Avatar
2021 Mercedes GLB250 4Matic
Not sure if the car will let you Close doors, while car is running and nobody in the car, however if you turn it off, lock, and remote start the engine the car will run for 10 minutes with AC on.
Old Oct 14, 2021 | 09:59 PM
2163amg's Avatar
2021 GLC 63 AMG
Hate having to turn off the car and remote start it, then manually start it again. It's 2021 after all this seems illogical to have to do these steps.
Old Oct 14, 2021 | 10:28 PM
W205C43PFL's Avatar
The remote start idea is great. There is another method, not sure if this will work but you can use your physical key (the metal key not the key fob) to manually lock the vehicle from outside once you have your engine on? First use the buttons to lock all the other doors then exit the vehicle. You need to remove the key cover first on the driver's door with that key and then insert the key inside, rotate to lock. Please confirm if it is indeed locked before walking away.
