Use GLA250 winter wheel/tire on GLB?
Thinking about These wheel spacers
Here’s specs on package, assume hub dia. and TPMS specs are same, but correct me if I’m wrong please.
18X8 5-112 ET35
A1028802GB GLOSS BLACK
SE A10-2{} 72.2MM
72.2-66.6 CENTER RING
***REQUIRES THE USE OF RCLIP**
RETAINING CLIP FOR AL RING
BC14X1.5 28UL 52TL 17H
REQUIRED LUGBOLT FOR VEHICLE
SI20#
17/19 TO 17MM LUG ADAPTER
BR17.1917
SCHRDR 433MHZ SENSOR
REPLACEABLE VALVE
8NM
8NM=71IN.LB
235/50R18~001117 101H
BS BLIZZAK WS90 XL
https://www.willtheyfit.com/index.ph...h=8&offset2=35
Compared to GLB250 set up your wheel size is going down 3.39% (2.86% compared to GLB35). They usually recommend staying below 3%. Also you are loosing nearly half an inch clearance. Lowering the clearance might not be good for snow and water puddles in winter depending on where you live... Again it is your choice...
I am jealous of your 35, I have seriously considered trading up to that, I thought I could live with the drop in performance, but man, it is such a huge drop. The midrange passing of my N line was better than even the 35, so the stock 250 is killing me, slowly.
