Adjust. Suspension with adaptive damping
https://mbworld.org/forums/glb-class...-amg-line.html
I had a loaner GLB250 last year, but I don't remember being too stiff, most probably similar to GLK350 with 19" wheels that I had previously. On GLB35 AMG, adaptive damping makes the car stiffer with sport and sport + mode. Adaptive damping is not air suspension to make it more comfortable... Even GLC 300 doesn't have the air suspension option in US unless you buy the AMG 43/63 models... However 2022 GLC300 suspension felt more floaty than GLB250/GLK350 when I had as loaners in last 2 months....
However, aside from a few exceptions due to poor implementations, an adaptive suspension is generally always an improvement over a fixed standard suspension for a few reasons. The challenge that suspension designers have is that comfort and handling are opposite goals. You can't have maximum comfort and also great handling with minimal body roll at the same time. Then on top of that are expected road conditions where the cars are most likely driven. So suspension designers have to find a compromise between comfort, handling and expected road conditions when designing a fixed suspension. This means it may not work well on all roads and in all conditions.
Adaptive suspensions change this. The main benefit of an adaptive suspension is not necessarily that the driver can choose between Comfort and depending on the model several sport modes, but an adaptive suspension continuously adapts multiple times a second to current road conditions and driver inputs to always have the optimal damping. This means the suspension continuously tunes itself to the specific road you are driving on, and your driving style to provide the desired balance between comfort and handling. In addition the driver can choose if they want the suspension to be overall more comfortable or overall more sporty depending on how they feel like, so the suspension works in a much wider range and is more optimally tuned to the actual road you are driving on.
Once you've owned a car with adaptive suspension for a while I bet you will find fixed suspensions lacking in their performance and comfort department. At least that's what happened to me. I find fixed suspensions very one dimensional now and I can tell right away that they are compromised. My C63S coupe is a firm riding car, but I find it more comfortable than many cars with a softer fixed suspension, because the adaptive damping is so much better in my C63. I can feel the bumps in the road, but the car settles quickly and the body doesn't move around, so I don't get thrown around in the seat which makes the ride more comfortable despite having firm springs. It's hard to really describe in words, and has to be experienced. You can just tell the difference in damping between a fixed suspension and an adaptive suspension. Then when I wanna go hoon it in the canyons I can put the suspension in Sport+ for excellent body control in the corners at the price of less comfort, but that's what I want at that point. As soon as I'm back driving normally on the highway or around town I can put it in Comfort for a nicer ride.
The GLB250 with 19” wheels and MOE tires definitely rides better than a C Class sedan with aggressive sport tires.
Suggestion: After the 19” MOE tires need replacing, switch to the same 19” MO tires that the GLK would have and buy a compact spare tire kit. Then enjoy the all around better ride. It will cost less than adaptive suspension and as a bonus, standard radials are repairable where MOE tires are not.
Do the struts & shocks have magnetic fluid in them or what is used to control their adjustability?
