GLB Class (X247) Produced 2020 to Present
Driver door handle makes lots of squeaking noises
Old Sep 22, 2023 | 08:02 PM
cleankutazn's Avatar
GLB 2023
Is this normal, my driver handle makes all kinds of squeaking plastic sounds when I pull on it or kind of twist it. The passenger makes a little noise and the rear passengers are pretty quiet. Can they fix it If I bring it to the dealer or say that's normal.
Old Sep 22, 2025 | 08:34 AM
Chalifoc's Avatar
GLB250 4matic 2021
Same for me...I still need to figure out how erase that freakin noise each time I touch the handle...
Old Oct 28, 2025 | 11:30 AM
kgzero's Avatar
2022 GLB250
Same on my 2022 model. makes noise when I pull on it, feels somewhat hollow. I plan taking of the door panels to check it out...eventually.
I was thinking of using window weld, like people have done in other forums, but if it's meant to split in two (the door handle I mean) so you can work on the door handle or take it off the door, I'll have to figure something else out. Maybe use Tesa Tape between the pieces that separate??
