GLB Class (X247) Produced 2020 to Present
GLB250 (2022) !NEED HELP!
Old Apr 6, 2024 | 01:19 PM
gektor21's Avatar
GLB250
Exclamation GLB250 (2022) !NEED HELP!
HI!
I have this problem
I need to replace the hydraulic unit with the board
This was taken from my car
А0009010404
R 247 377 32 00
This is a gearbox from another car:
Р 247 377 06 00
VIN: W1N4M4GB3NW236255
I found a gearbox with the same block from the same car, but the code on the valve body matches and I also think it won’t match on the board (it’s not visible because it’s not disassembled)
What do you recommend on how to check? And will there be one more thing that needs to be programmed after the replacement?
I also have a question: are all the transmissions on these cars 8 speed or are there 9 speed ones?
