GLB Class (X247) Produced 2020 to Present
GLB 1.3 vibration @ 1900rpm
Old Apr 12, 2024 | 02:25 PM
jrwestham's Avatar
GLB 200
I get a vibration when car is at 1900 revs. It appears its just at the point before it changes gear.
At last service I pointed out it had a vibration at 1900 rpm and they kept car overnight to run diagnostics on the gearbox but found nothing.
Also the engine management light had come up a few times but when I told them they replied that nothing was stored on the ECU !!!!!
However today the light has come up again and performance is down I guess this is some sort of limp mode.
Old Apr 14, 2024 | 02:10 PM
ninjutzu's Avatar
GLB 200d (2020)
Well, not directly related to your vibration, but I got very strange behaviour from tmy car (GLB 200d 2020 model), all kind of errors, camera obstructed, radar not working, coming on and off randomly, at least once every day if not more than that some days.
Then one day, after all this errors, car went in the limb mode so max speed 100km/h and max rev 2000 rpm. Stop engine, start engine and it recovered. All looked ok.
Went to dealer and complained (car is under warranty), they told that there is no error in the ecu, all is fine....well, I had pictures of all the erros so I told them that I don't give a rat *** if there are errors recorded or not, but I have plenty of pictures and witness to prove them, including the limb mode.
So they kept my car for a day and conclusion was that the steering wheel axl with all the steering wheel contacts and the left side steering wheel buttons and the camera where malfunctioning. They ordered the parts from Germany and replaced them all, it took three visits to service and some pictures to convince them that I'm not joking. So go there and tell them to look as limb mode is not a good thing and something for sure is broken.
About the vibration, I had in the past a B-Class 180 CDI with CVT that was vibrating on idle and could not keep constant rev when idling, result was some broken "black box" between engine and gear box. Three days they worked on the car to replace it as engine and gear box needed to be removed. All this under warranty so just be insistent. That vibration is not out of nowhere. There is a cause. I hope that you will get it fixed.
Old Apr 15, 2024 | 04:44 AM
jrwestham's Avatar
GLB 200
Thanks for reply, after 2 days with engine light up it cleared and all back to normal.
Spoke to manager at another MB dealership who replied that if fault shows up ECU should register it.
Even though the other dealer couldn't see anything !
He is going to investigate my car and hopefully find issue.
The vibration is there when I'm in D3 and doing 23mph and revs are at 1900rpm, but got to be on a flat road to feel it.
Old Dec 8, 2024 | 05:22 PM
cljxr27's Avatar
Well I got a recall letter for the steering software. 2nd dealer I went to did a B1 service and software update on steering.5 days later I got the EML up again. But cleared later that day cleared. Dealer said they would try and check using MB APP which they will try tomorrow.
Old Apr 23, 2025 | 02:38 PM
Jobz's Avatar
Hi, i searched the internet and the problem you describe is exaxtly the problem im having. My dealership cant fins the problem. Is your problem solved by now?
Old Apr 23, 2025 | 03:26 PM
jrwestham's Avatar
GLB 200
The Engine light comes up intermittently but nothing recorded on ECU.
The vibration is still there at about 1900 revs especially when in D3
Old Jan 14, 2026 | 09:21 AM
cljxr27's Avatar
Vibration is still there at 1900 rpm buy fou d this about the M282 engine
" Also worth noting, the M282 engine is the first four-cylinder Mercedes-Benz engine to feature a cylinder deactivation system (in connection with the 7G-DCT gearboxes). The motor can shut off the second and third cylinders in the partial load range between 1,250 and 3,800 rpm."
This is in RPM window that I get a vibration?
Old Jan 14, 2026 | 10:57 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
That brings a whole new perspective to the discussion. The M282 is also used by Renault, so maybe looking on one of their user sites could be useful.
