GLB Class (X247) Produced 2020 to Present
Tailgate Opens 3/4" and Stops.....
Old May 23, 2026 | 05:09 PM
OUZO Power's Avatar
JGC SRT, ML 550, GLB 250
Has this happened to anyone?
Our 2021 GLB 250 just started doing this. You hear it fine when pulling the switch from inside and then it stop after 3/4". Then I have to go outside and manually open it.
Same happens when I try to open the hatch from the back.
From outside though when I press on the close or lock buttons it works fine and shuts.
Thanks.
Old May 23, 2026 | 09:25 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Thanks.
When the hatch encounters an obstruction it stops. It doesn’t take much force to stop it, so if the lift cylinders are getting weak, that coild be the issue.
You probably know this if it’s not new to you, but if you stop the hatch with any of the buttons on the door, hatch, or remote, the door will remember that and always stop there. We have ours set about 6 inches short of full open to avoid the overhead door when in the garage.
Old May 24, 2026 | 01:49 AM
OUZO Power's Avatar
That's what I'm thinking. The power struts are giving up most likely. Thanks for the reply.
Old May 24, 2026 | 03:44 AM
trigital's Avatar
W213 All-terrain
Thanks.
You may have a Menu in MBUX where the Garage limit can be enabled
Old May 25, 2026 | 12:47 PM
OUZO Power's Avatar
There is no MBUX option. Looks like the struts/motors have given up. When they stop and I give them a tap they wake up again.
Old Jun 5, 2026 | 05:39 PM
OUZO Power's Avatar
I just ordered now shocks. Will wait till the factory ones completely fail cause it started to work again.
Old Jun 13, 2026 | 03:30 AM
OUZO Power's Avatar
OK I replaced the shocks/motor. FIXED.
Pretty pathetic if you ask me a premier brand like MB to have these fail within 5 years. My 16 year old ML still has the original ones. Aliexpress $200. MB OEM about $1K.
And replacing them is really a PITA. You have to take off all the rear interior pieces. And then a lot of fishing through the connectors and wires. I have cuts on my hands all over them.
Everything works inside and out with one exception.
And I truly can't recall if that's how it was before as this is my wife's ride and I barely drive it. When I open it from the inside it opens all the way with one pull of the button. But when I want to close it a one touch just moves the tailgate a smudge down. To completely close it I have to push on the button till it completely closes. Is that how it works for you guys?
Old Jun 14, 2026 | 02:26 AM
Odd Piggy's Avatar
Good to hear that the new gas struts fixed the rear gate opening problem. Our ‘21 GLB250 doesn’t seem to be weak at this point and the gate gets used maybe 5-10 times a day. It carries kids, dogs, and cargo.
At 100k miles, I don’t see any reason not to use aftermarket parts on non-safety related body components. And MBs built like your ML disappeared around 2014-2015 — look under the hoods — the ML has 2 gas struts, the GLB has one — cost savings throughout. I still haven’t gotten over the fact that MB chose to test an unproven engine design on their customers. But it’s not all bad, either.
On my ‘23 GLA250 I have to hold the door button to close, but it closes all the way with either of the buttons on the gate. If my wife’s ‘21 GLB work differently, I will post it when I get a chance to check it out.
Old Jun 14, 2026 | 02:56 AM
OUZO Power's Avatar
ML hood though weighs twice as much. But yes. You can see the difference in the build. So different and intended to last back then.
I asked my wife. She confirmed what you say about your GLA. You have to hold down the interior button for it to close. So everything working as intended.
