Dash cams for glc
On my car I have the Snooper dash cam that also picks up speed camera alerts.
Worth the money!
My criteria, no GPS, to avoid issues if car slightly over posted speed limit, robust for heat build up in cabin over summer, some stop working until they cool down. No LED lights on unit, reflection on front screen and it tells everyone you have a camera. Look for G sensor, field of vision from 140 to 170 degrees, resolution at 1920x1296p minimum, 2034x1296 p good, with still resolution highest you can get, better than 5mp. Lens of quality say F1.8 or F2 as minimum for max light transmission, helps with night view.
Ambaralla A7LA30 is a good all round processor. Prefer small platform, not big or bulky.
Mini0806 is proving very good at the moment for me. CDV300 looks interesting.
Will install two cameras, one on front screen and one on rear window, using 12 v outlets. Most likely two independent cameras as the ones sold as linked pairs have different resolutions and require hard wiring either through the headlining or under floor along side. If seperate, then if one faults the other still works. Will be installing in GLC and Mazda3. Will be low profile units like Mini9806, or later model. Some good ones from Korea currently, but a bit $$.
0806 has been troublesome with freezing issues and no automatic use of the dual microsd.
Also overheating is an issue with Li-ion battery based cameras.
I'm awaiting the capacitor type powered units prices to come down a bit.
https://dashcamtalk.com/
Cheers.
That been said, has anyone installed a 2 channel dash cam on their GLC or estate?
I have routed the power cable to the rear trunk (surprisingly eas) and connected via power magic pro. If anyone requests will post pics once completed.
apologies for the reflection... any higher the image would have been too skewed... Any lower, it's gets in the way of driver vision...
Power cable running along to the bottom of the trunk...
excuse my wiring.... going to get some fuse taps tomorrow to clean this up, yep victim of OCD!
This is what I've resorted to attaching the ground.... bit difficult as there isn't bolts to body near the fuse box. A
Maybe the next Generation
Thank you very much.
The ACC - i've used the front Cig lighter. For connection I used fuse taps https://www.jaycar.com.au/double-min...e-tap/p/SF5125 - may not be the mini, but you get the idea.
I'll take a closer photo when I'm home, but I hope this gets you going.
Cheers
I hope to get the install going well on 2-channel setup, i'll report back if anything. I've noticed my fuse box located in the trunk, mostly if not all, the fuses. after the ampere rating has letter N. For example, 5N, 10N, 15N and so on..
Normally, the fuses amp should just have the rating 5, 10, 15 and so on.. never seen before where a letter N was included until now.
for grounding, I saw an empty screw hole that was threaded and used size #8-32 x 3/8 in., flat head Phillips.
In my car I have a Panorama II. In 2014 it was $200 (or so) and it had the best night performance. Since that time, I think there are better night performance cameras
So far the camera I'm leaning toward is the Thinkware F770. Pricy but has everything one would want in a dash cam...I think.
