Front plate mounting
Old Apr 11, 2016 | 04:42 PM
Jason Zhang's Avatar
GLC 300
how did you all mount the front plates? dealer drilled holes? or has someone here found some sort of alternative?
Old Apr 11, 2016 | 05:28 PM
MB Marko's Avatar
2012 C300 4Matic Sport Sedan
If I was ever buying a new car I would tell them numerous times not to drill holes! if they do they can buy a new front bumper. find another method of mounting either the tow hook plate or something else. once you drill its a pain in the *** to plug them and its just an eye sore, at least you have the choice in a new car I bought used and now those 4 holes are limiting what I can do.
Check the laws regarding front plates where you live sometimes that can give you an idea of what to do example getting Vinyl Transfer on reflective check this out pretty sweet idea I would of done it if the 4 holes weren't so bad on my car
also I should add theres lots of good options in that thread
https://mbworld.org/forums/c63-amg-w...have-pics.html
Old Apr 11, 2016 | 05:35 PM
GLC 300
it's illegal here:'(
Old Apr 11, 2016 | 05:38 PM
MB Marko's Avatar
that was just an example what about http://rhoplate.com I would go tow hook or find something that goes in the lower grille
Old Apr 11, 2016 | 07:25 PM
larrypmyers's Avatar
Veteran: Air Force
16 GLC 19 Volvo XC40 06Corvette Z06
The dealer drills two holes allowing mounting of the plate holder.
Old Apr 11, 2016 | 07:40 PM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
My dealer used two self tapping screws on both my c class as well as my GLC. Same was done on my GL. Prior to that I drove without front plate until state started enforcing.
Old Apr 11, 2016 | 08:11 PM
07SGT's Avatar
2016 GLC 300 4Matic
Concur that if dealer were to drill holes I would tell him it is now his vehicle. My state requires a front license plate and I do not mount it as I will not drill holes in a Mercedes. There are mounts made that are hidden under the front and slide out when needed. They are on amazon or ebay. I keep the plate in the trunk area if stopped and would say I am waiting on the dealer to obtain a front mounting plate. If I have to pay a fine I will but I will not drill holes in a Mercedes.
Old Apr 11, 2016 | 08:30 PM
freinhar's Avatar
GLC 250
We are required to display front plates here in Australia.
I use Lakin plate brackets on both the front and back of my vehicle, have found them to be of very high quality and they are designed to protect the paint of your bumper, unlike some cheaper brackets which will bang and rub against the paint.
Old Apr 11, 2016 | 10:38 PM
07SGT's Avatar
2016 GLC 300 4Matic
Old Apr 20, 2016 | 03:48 PM
JEVA's Avatar
2013 BMW X6 - Soon to be GLC300 4M
http://www.usmillworks.com/
