Current Opinios of The 9G
Old Dec 24, 2016 | 11:01 PM
RJC's Avatar
RJC
Various
Current Opinions of The 9G
What are your current thoughts?
TIA
Old Dec 24, 2016 | 11:34 PM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
No issues so far in 10 months. Works well. No complaints.
Old Dec 25, 2016 | 12:25 AM
RJC's Avatar
RJC
Various
I have this trans in my S coupe when shifting from 3-4 under very mild acceleration I'm getting a rougher shift and feel the torque converter engage just before the shift occurs...no other gears have this problem. Apparently some of the new E class' are having similar issues. Is yours a 4matic?
EDITED
Old Dec 25, 2016 | 11:48 AM
FrostyZoob's Avatar
2017 Mercedes-AMG GLC43
Is it possible that there's a dog clutch being used between gears 3 and 4? If so, that might explain the different behavior you're feeling. I assume that the 9G uses at least 1 dog clutch since ZFs 9 speed uses 2 AFAIK.
Old Dec 25, 2016 | 11:54 AM
begone's Avatar
Overall working well. There's a weird shift spot that either downshifts hard or upshifts hard in comfort mode. Not sure exactly where it's at, but it happens when its cold and don't notice anything negative after its warmed up and ran through the gears a few times.
Old Dec 25, 2016 | 11:59 AM
dieseldoc's Avatar
EDITED
Mine is not a 4matic.
Old Dec 25, 2016 | 03:12 PM
RJC's Avatar
RJC
Various
i don't know, but it is only under light throttle and anything beyond that the 3-4 shift is smooth and with no torque converter lock up sensation. The 7g had a similar sensation during 2-3 but much less noticeable. The problem like others have mentioned in the w213 forum doesn't always occur but it does about 50% . This appears to be the only flaw and I hope MB gets a software flash out soon.
Old Dec 25, 2016 | 09:56 PM
Penn's Avatar
GLE 350D GLC 250D, Previous vehicles W204, W164, W163, W210 & W202
The 9G is a much better transmission than its predecessor the 7 speed.
It is much smoother on downshifts.
Old Dec 25, 2016 | 10:25 PM
RJC's Avatar
RJC
Various
Agreed.
Have you experienced the 3-4 light throttle shifting issue described above?
Old Dec 26, 2016 | 10:05 AM
guido3's Avatar
2016 GLC300 4Matic
The big plus with the 9G is that the top 3 gears are overdrive, which, of course, improves mpg markedly. With my 4Matic, shifts are very smooth, and manual downshifts on long hills work flawlessly. I find no fault with it.
Old Dec 26, 2016 | 10:24 AM
dejongj's Avatar
right to be forgotten
Never had the 7G in my GLC.As such can't really compare it.
I had the 7G in my GL and it was absolutely fine, I have the 9G in my GLC43 with some AMG magic applied to it and it is also absolutely fine.
Old Dec 26, 2016 | 03:14 PM
dieseldoc's Avatar
As stated earlier have 9g in my GLC. No complaints. Have 7g+ in my c class, no issues. The 7g in my GL had occ rough shifting.
Old Dec 28, 2016 | 07:55 PM
Teckno's Avatar
2016 GLC 250d AMG pack, 2017 GLC Coupe 250d AMG pack , 2002 BMW 330Ci convertible, 2021 BMX X1 sD20i
Hi, GLC 250d. 4matic with 9g auto tranny.
Very happy with changes and performance. Sports+ is whiplash territory while comfort mode lopes along. Maybe due to diesel torque, but it does not "hunt" for any gears and copes with steep grades, both up and down hills quite well. Adaptive cruise works very good with 9g as well.
We have travelled 21000km to date.
Old Dec 29, 2016 | 03:51 AM
dejongj's Avatar
i agree that the 9g is a great gearbox, and very well mated to the car. But a 250d whiplash territory? Seriously? I felt like Fred Flintstone driving one; I.e. Get my feet out and push it along as I already had the "pedal to the metal".
It it really makes me wonder what the reference framework is. Mine before the test drive was our big heavy beast the GL 350d which has more oomph with its 7G gearbox.
Old Dec 29, 2016 | 04:07 AM
Teckno's Avatar
Sorry Fred, it's all relevant, as you said. Maybe South of the Equator helps with the axis of the world spinning, down in Oz Land we might benefit from sling shot acceleration as astronauts do ? ; or you need new Roman sandles from Bath ? Lol.
But seriously, yes anything from MB with AMG badging will go very well. The humble 250d Down Under works just fine in Sports +, as we have lower speed limits before Mr Plod steps in with a speed camera.
Enjoy your ride.
