Logically speaking, if there is enough moisture within the housing to form condensation, wouldn't it means that either the headlamp seals are not doing the job or there are excessive moisture trapped during the manufacturing process?
Anyone have any idea on the design of the headlamp units to understand if there are some valve that allows air pressure equalization as well as one way moisture release?
This is normal. The lamp housing allows a certain degree of condensation to prolong the life of the bulbs. there is a membrane behind the housing to manage moisture. safe level of moisture that is
