GLC300 4Matic very high fuel consumption
can I add the following.
check Tyre pressures, try setting all at 36psi
buy a fuel tank and injector additive, add it to petrol tank and fill up, take care to try and fill as much as possible as you will need to do same technique when you refill normally later to try and obtain same fill level, that way you can manually work out mpg, using fuel added and miles driven.
borrow a hand held, vehicle map GPS unit and measure distance travelled to compare with speedo.
also use portable GPS to compare mph on gps to mph recorded in car, try it at various posted speed limits to confirm accuracy across all driving ranges - can be out by 2 mph I think, any more you may have an issue.
confirm you have minimal load in car and under trunk.
check engine oil levels and radiator while your at it.
my guess is the MAS sensor could be out or air leak in line of turbo, causing too much fuel to be burnt.
what colour are inside of exhaust pipes ? Are they very black and deep soot or fine grey and smooth ?
Dealer really needs to do fuel air mix analysis and download Veh telemetry to confirm
hopefully your brakes are not engaged and constantly slowing you down, lane assist can kick in and brake Veh very slowly if you travel close to the white lines and not in the middle of the road.
still sounds like fuel mix sensor with turbo or injectors malfunction with engine management system over compensating to make car work.
good luck, let us know how your get on.
Do you always use the same gas station if so maybe try another one?
Outside of the definitely try to get the dealer to diagonose it . If your dealer is not responding maybe time to go somewhere else
