RFT vs NRFT
MB GL320bluetec
RFT vs NRFT
My 2009 GL320 blutec has Bridgestone 275/50R20 run flats that have 4mm tread left and dealer says they should be replaced soon. I hate run flats. Can I put regular Michelin or Scorpions on instead?
Actually this new gen of tires are termed " Extended Mobility as new gen is a different construction than original Run Flays.
There are GREAT choices out there in NRFT - and some great tires at "affordable" prices well under $200 usually on sale at Tire Rack.
If you lease your GLC - you will want to save your RFT's to put back on for lease turn in.
Common to switch to NRFT = add a can of Fix-A-Flat (or equivalent go) in the trunk,
Happy hunting - keep the beat !
