Command screen not working
Old Mar 20, 2018 | 04:13 PM
James.scicluna's Avatar
GLC350d
My GLC350d is almost new. All was working properly, except that this evening when I turned the engine on nothing appeared on the iPad-like screen. Tried turning the system on and off a few times and also a few engine restarts. Nothing. Does anyone have any tips or guidance please?
Old Mar 20, 2018 | 04:37 PM
Rmlasalle's Avatar
2009 ML350 and 2018 GLC
Did you try the on/off button on the right side of the center console?
Old Mar 20, 2018 | 04:49 PM
GLC350d
yes several times
Old Mar 20, 2018 | 05:04 PM
ennedomi's Avatar
GLC 250d 4Matic Premium
It happened three times to my command screen. The mb service detached and attached the battery to restart the system. It happened also in the Glc of my colleague. According to me there is something wrong in the hardware...
Old Mar 21, 2018 | 12:49 AM
GLC350d
Damn it. Nothing of the sort ever happened on my good old c220d sport’s command screen. That’s a November 2007 model and the command and screen have always worked perfectly. Guess I’m going to have to take the glc in to the dealership. Thanks for your feedback.
Old Mar 21, 2018 | 08:36 AM
matts's Avatar
'23 EQS 580
I have had the issue a few times where the command system would take a few minutes to boot up. Service has told me this is normal (I disagreed.) However, one way to manually reset that has worked for me is holding the cd "eject" button on the dash for 10-15 seconds until the system hard resets. I continue to drive while this reboot occurs with the only issue being no command activities until it boots up, which is generally about 1 minute. I do find that after a reset, all seems to be good for a little while. I only have the issue with command not booting up quickly maybe a couple of times a month or less.
Old Mar 21, 2018 | 06:40 PM
ennedomi's Avatar
My problem was different: during the blackout, the command tried to start several times without success... I suppose it could be caused by a low level of battery. Before the end of warranty, I will ask a deep check.
Old Mar 21, 2018 | 07:16 PM
madelko's Avatar
Veteran: Army
2017 GLC 300 4Matic
Same here last weekend. Finally re-started itself, but went black (off) again. Took car to Service this morning, but as they were punching buttons, it started itself again. Service gentleman said a possibility of a bad Sirius update might be responsible. I'm not endorsing this possibility, just reporting his comment. Only thing that worked during this blackout was the rear camera when you put the car in reverse. Absolutely everything else was not available. On the dash screen, the words RADIO OFF was displayed, that's it!
Old Dec 9, 2018 | 10:25 AM
Yaz Al's Avatar
E220 CDI 7G
Check your fuses and replace all fuses linked to the comand system. You will find a guide to which fuse you need to replace online.
Old Feb 15, 2019 | 10:14 AM
KyanaDixon's Avatar
glc 300 coupe 2017
thanks holding the eject button worked for
me
Old Jul 11, 2019 | 11:48 AM
ezd333's Avatar
Mercedes C Class 250d
Worked for me too. C class 250d 2015
Old Jul 13, 2019 | 02:54 PM
Jetfuture's Avatar
2016 GLC300
FYI, It's COMAND, with one M. It's an acronym for COckpit Management And Navigation Display.
Old Jul 15, 2019 | 05:10 AM
Teckno's Avatar
2016 GLC 250d AMG pack, 2017 GLC Coupe 250d AMG pack , 2002 BMW 330Ci convertible, 2021 BMX X1 sD20i
Suggest placing car battery on overnight charge. Have found that a ‘low’ battery will cause this and with a proper top up, the car will behave. Driving around is not enough to charge sometimes. The lack of Comand access has proven to be a low battery in the past, unaware at what % this over-ride kicks in to support other safety CPU’s.
Give it a try and let us know.
Old Nov 7, 2019 | 05:54 PM
sagowun's Avatar
2017 C250d Coupe
Eject worked on my 2017 C250d coupe
Old Nov 24, 2019 | 05:41 AM
Moka Id's Avatar
c450 - 2016
Screen Blank only during youtube streaming !!
hello guys
I own c450 - 2016 .... pairing my mobile to the command screen is working perfectly .. even streaming music from the mobile library is working all the time perfectly
but it comes to stream from youtube it goes blank !! any idea?
Old Jul 14, 2023 | 07:30 PM
Gforce007's Avatar
E Coupe 220d
Hi crew. I'm considering buying a 2018 or 2019 C class coupe. Do the comand screens fail after a couple of years? Thanks.
Old Oct 28, 2023 | 04:10 PM
Apasq's Avatar
2019 C43 amg coupe
Im on this page because my 2018 controls did apple play just stopped working and it’s stuck on Google maps
Old Oct 28, 2023 | 04:17 PM
mikapen's Avatar
Most of the problems we've seen with Carplay have been solved with an Uninstall/Reinstall of the most recent app version. It doesn't look like Apple updates their app without.
Old Oct 29, 2023 | 12:12 PM
Apasq's Avatar
2019 C43 amg coupe
thanks man! Do you mean uninstall/reinstall the apple car play on the car? Or Google maps since that’s what it’s frozen on? Made me think to just delete that app then plug the phone in and see if controls start.
any help would be awesome. Lost with google maps and traffic, literally lol.
Old Oct 30, 2023 | 12:35 PM
mikapen's Avatar
Reinstall the phone app.
It may or may not work, but it's the easiest to try as a first step.
OTOH, Apple's security modes don't always play nice with others, and it often takes a car's system update to resolve.
Hope it's the former for you. Good luck.
Old Dec 15, 2023 | 08:35 PM
dremorg1's Avatar
GLC43 AMG
Damn! Now mine. Black screen and none of the buttons on the center console work but my cell is still linked to the car because my playlist works and i can hear Waze. Just don"t see anything. Which fuses are connected to the COMAND system?
Old Dec 16, 2023 | 03:21 PM
mikapen's Avatar
There is a setting that can turn off the screen completely.
Are you sure you haven't that switched it off advertently?
Old Jan 6, 2024 | 04:26 AM
Cathymark74's Avatar
E250 CDI amg
Black screen
My command screen went black as I was rebuilding everything after fitting an android auto kit. I have a 2014 e class with the NTG4.7, all connected up ok and seemed to have all the android auto functions available, I started screwing the screen back in when the display went off, undid the screws and the screen came back on, took it out checked connections and tried again and this time the screen went off again and stayed off. I assumed my problem was that I had fitted the android auto control box behind the screen and that the screens blue video connector was pressing on the control box as I tightened the screws. So I removed everything and put it back to standard but still no screen. Managed to get another screen from eBay and fitted that last night but unfortunately no difference. Have tried some of the resetting procedures, eject does nothing on my unit but holding the power for about 10 seconds shuts the command unit down and it restarts in a couple of seconds but still no screen, not sure if this is connected to my problem but none of the buttons around my command control knob light up either, not even sure if they are meant to light up but maybe related, you never know? Will probably remove and check all connections on the back of the stereo later but anyone got any ideas? Fuse locations etc worth checking?
