GLC Wood Steering Wheel
there is at least one steering wheel for each trim. The Linden wood will be kinda hard to match because it comes in two darkness; also I believe it is called Eukalyptus globally instead of Linden Wood.
You can contact forum member Chris_the_swede, go to your local dealer parts counter, or look on the used market.
There are many variants, so you would need to do the research and cross link the options on your car. You will need to change the buttons if it is from a GLE, GLS, SL, SLC, CLS. I have never seen a C, GLA, GLC, CLA with a wood steering wheel. The flat bottoms can start at $1000 USD on the used market; they are well over $2000 USD new. The round bottom are usually less than $800 USD used.
