Lights question
Old Dec 15, 2018 | 05:02 PM
RedKloud's Avatar
BMW M340i, Mercedes GLC 300
Lights question
Is there a way to turn the headlights off while keeping the DRL on?
Old Dec 15, 2018 | 05:15 PM
Tylbran's Avatar
2018 GLC 43 & 2014 SLK 350, gone 2016 E63 Wagon
I believe that you can move the headlight switch to "off" (and not auto) - the headlights (and taillights) should remain off. I just keep it on auto so the headlights are on when the daylight gets low enough. I have seen many people driving with only their DRL's on and it is dangerous since in the dark you cannot see them from the rear unless they put their brakes on.
Old Dec 15, 2018 | 05:36 PM
RedKloud's Avatar
But this turns the DRLs off too, at least here in US.
Old Dec 16, 2018 | 09:09 PM
Tylbran's Avatar
Probably true. In Canada we cannot turn off DRL...and why would you?
Old Dec 17, 2018 | 10:08 AM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
Cannot turn off DRLs on USA models. There is no off position on the switch.
Old Dec 17, 2018 | 10:28 AM
ajmtbm's Avatar
Mercedes-Ben GLC300 4Matic
if you go into the settings menu (on the screen between the tach and speedo) there appears to be a setting where you can turn the DRL on or off..
Old Dec 17, 2018 | 11:14 AM
Philamg's Avatar
GLC 450
Illegal to turn off if fitted in UK.
