Rough Shifting
Old Jan 11, 2019 | 09:57 AM
brady's Avatar
2018 GLC 300
Rough Shifting
Anyone with a GLC300 experiencing rough shifting from 1st to 2nd in SPORT mode? Downshifting seems to be OK, but upshifting is really rough and slowly becoming worse. Not noticeable in "Comfort", but pretty bad in Sport (and Sport+ and Individual modes). 2nd to 3rd on up seems OK.
Did a forum search and found a similar issue, but didn't seem to be the same....
2016 GLC300 - 9500 miles
Old Jan 11, 2019 | 10:49 AM
ajmtbm's Avatar
Mercedes-Ben GLC300 4Matic
have you gotten a software update? there is one available, so if you describe to your dealer i imagine they would update the software that may help.
Old Jan 11, 2019 | 11:05 AM
brady's Avatar
2018 GLC 300
No software update yet, but I think I'll need to take it in soon. The problem has consistently gotten worse, so is likely something else.
Old Jan 13, 2019 | 11:01 PM
Petmerctech's Avatar
Ask for any software updates and to have shift adaptation done.
Old Jan 16, 2019 | 10:52 PM
Airbag's Avatar
E 450
does the problem seem to go away when it warms up?
Old Feb 23, 2019 | 04:07 PM
brady's Avatar
2018 GLC 300
My GLC 300 issue with rough shifting from 1st to 2nd in Sport modes seems to have been resolved after a few days at the dealer. Appears the ATF was low, but not sure if that was the issue or if it was the software update and related shift adaptation tweaks.
Anyway, here are the service notes, just in case others might have the same issue. And a quick shout-out to MBZ of Austin for excellent service.
________________
"Multiple causes. Test drove vehicle (9683-8686, 9:01-9:23), during road test, verified slightly harsher shift 1-2 in "sport plus" and "individual" drive modes. Connected battery charger and performed short test. No relevant fault codes were present or stored in ME, ETC, Powertrain, ESP, etc. Checked/corrected fluid level in automatic transmission. Generated control unit logs and logged EEPROM data. Performed transmission adaptation for shift 1-2. Consulted with shop foreman, performed software update on ME & Transmission control units. Performed SCN coding. Test drove with shop foreman and compared to like vehicle. Vehicle of the same chassis, engine & transmission variant, and model year behaved the same way. Released vehicle."
