Problem on GLC Hybrid
Thank you in advance.
Secondly, on another occasion a few weeks after the first problem, I was driving and probably stuck in traffic for about 20 minutes. Suddenly a message popped up saying “Coolant Too Hot Stop Vehicle Turn Engine Off”. I pulled at the side of the road, turned off the vehicle and then waited for about 30 minutes before trying to get safely home. When I restarted the vehicle the warning message was off but the check engine light was on. I was able to drive for a few minutes before the warning message came on again. I again pulled safely on the side of the road and waited another 30 minutes before attempting to get home. I got home safely on the second try without the light coming on but the check engine light remained on. After a few hours, I got a friend to check the coolant level in the vehicle and the level was where it needed to be. I took the vehicle on a drive the next day, the check engine light was on but warning message never reappeared.
Two days later when I needed to drive the vehicle, I the noticed that the check engine light was off and the warning message was not there. I still contacted the dealership and reported the incident. I was advised that if they were to do the computer diagnostic, it will only show the codes that related to check engine light being on and then I would have to decide if I wanted to do the relevant repair or not especially seeing that the vehicle was running fine at that point and that the check engine light was off at that point. I was advised to monitor the situation and as soon as I see the message again to contact them to arrange to bring the vehicle to them. The vehicle was serviced by them on Tuesday, February 2, 2021 and it was noted that nothing seemed to be out of the ordinary.
Thirdly, about a week ago on a Friday evening, as soon as I unlocked the vehicle and sat in it, I noticed a red warning message that showed a picture of a battery along with the word “Malfunction”. I was still able to start vehicle but also noted that check engine light was on. I needed to pick up my son, so I still decided to drive the vehicle. I then noticed that the air condition was not cooling even at the coolest setting. I went about 5 miles away and all during the drive the light along with the warning message were on. Also the air condition was still only blowing hot air. I turned off the vehicle for a short time when I reached my destination. When the vehicle was restarted, the warning message was gone but the check engine light was still on. The warning message did return during my drive but throughout all of this the A/C was not cooling.
I took the vehicle to the dealership and they’re saying that my AC condenser needs to be replaced but can’t specifically say that it will solve the problem with the battery malfunction warning.
This is a practically new vehicle. Anyone experiencing the same issues?
Our GLC 350e had transmission problem when it was only few days old. Sometimes we could not put it into reverse, the screen said "reverse not possible" and also check engine light came on. It was transmission conductor plate.
We did not experience any coolant too hot problem, but I read it online (Quoted from Mercedes Facebook, couldn't post link here: Finally with the help form engineers from Germany, it took 3 months for them to identify and fix the problems : manufacturer defective wires, burned wire harness, wrong thermostat installation...So far, the car still has burned plastic smell after a drive. However, for Mercedes, everything was fixed since all the tests showed no problem.)
I also had the same warning message on high voltage battery which usually appeared when the weather was around 30~40F. It was the AC compressor.
We had other issues with engine mount causing excessive vibration and coolant hose leak.
in the quality.
