AutoTalent | Renntech Ecu + Exhaust + Suspension For Mercedes-benz GLC 43 AMG
SPONSOR
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/1024x153/e3h3wk5_1abcfc2abb0ad1bcfe01742da6c811693ce01e2b_7f416b71423a35e1f25fcd5108130cecf2e0a5cd_c07c2519b7319a7502a5ff07720821f06fbbc6f2_4673d377652875_95f5be43737458179762b3c8510f27164209a418.png)
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/1024x148/7vvm3jc_2a487a29958e257154f24ea3d382cdf0339a4083_35e1b34539289a661bbc69a4611261372dd082c8_fd90fc8225e22a7ad7bb53f7046a767bde8429e2_33f3f77445246_ec0050e9aefa5bd708aea2d20c87511a47ee6f03.png)
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
Click HERE to order Performance Ecu+!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
Features
Long-lasting and Driver Reliability
Significant Gains in Horsepower
Increases the Performance
Significant Gains Torque
Increasing the Engine's Rev Limiter
Incredible Performance Gains
Stock Performance
362 HP @ 5,500-6,000 RPM; 384 LB-FT @ 1,8000-4,000 RPM
375 HP @ 5,600 RPM; 398 LB-FT @ 3,300-3,600 RPM
Modified Performance
400 HP @ 5,450 RPM; 440 LB-FT @ 3,250-3,600 RPM
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_hht_001_f43cf55ca57611694b3c7349375b4b08f442dc82.jpg)
![](https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_hht_002_ad505674c0a4b7c816f20a2a5f8e9b2a4b11c5fd.jpg)
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_hht_003_d298e48962deb5b2f69575f63e5e62c836d1d8b2.jpg)
Renntech Hand-held Suspension Module
Click HERE to order Hand-held Suspension Module!
The RennTech Hand-Held Suspension Module (HSM) is designed to work with the GLC-Class X253, equipped with the Mercedes Airmatic and Magic Body Control Suspensions.The unit allows the user to have full control over all four corners of the vehicle’s suspension and adjust in 1mm increments. The HSM comes pre-loaded with a RennTech lowering setting. User can load their custom setting onto the HSM to set the vehicle to their preffered ride height. The desired lowering setting will be loaded onto the vehicle via the ODB2 port in the footwell of the car. After plugging the HSM into the ODB2 port, the user can toggle a switch to load the factory or the adjusted ride height. After a few seconds, the new setting is uploaded and the car will adjust to the new height. The factory setting will always be stored on the HSM and the user can set the vehicle back to the factory setting. Once the settings are loaded, simply unplug and store for future use. With the newest update to HSM, the user is now able to adjust the suspension settings directly in the on-board command system in their Mercedes. After plugging the HSM into the OBD2 port, the RennTech HSM Screen will appear on the Mercedes Command screen. After changing and saving the settings, the module can be unplugged and the screen goes back to the regular Mercedes menu. No tools, laptop or tablet needed. Full Plug'n'Play Solution. All RennTech HSMs are adjustable via USB using either Windows or Android OS.The software allows the user to adjust the ride-height at each corner in 1mm increments independently. The software also has three locations where the user can store pre-configured suspension setups for quick changes.
Features:
Allows the user to have full control over all four corners of the vehicle’s
Adjustment increments: 1mm
Maximum Lowering: Limited only by vehicle
Adjustment Methods: PC or Android (Tablet)
Size: 73mm x 44mm x 24mm
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_hsm_007_copy_7d244ecd31a0661f60834482f4808bac5267d25f.jpg)
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_hsm_003_de6bf3eb3ce0ce296d9bf9c46d9c10c8cce57acb.jpg)
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_hsm_004_5e99f2bc5233e72b7d58000bbc15ffb961d09892.jpg)
Renntech Exhaust Valve Module
Click HERE to order Renntech Exhaust Valve Module!
RennTech plug & play EVM Exhaust Valve Module allows you to open the exhaust flaps of your car 100% at all times by pressing Button 1 on the remote control. If you wish to go back to factory settings simnply press Button 2. This gives you complete control over the exhaust sound and rumble of your car at any time regardless of speed, RPM or driving mode. The RennTech Exhaust Valve Module is made in Germany. If your car is equipped with factory exhaust flaps, with or without a center console button to open or close them, factory settings do not allow the flaps to fully open unless certain speed and/or RPM have been reached. For example, while cruising the exhaust flaps will never fully open.
Features
Activation Completely Independent Regardless of Drive Mode
Override Your Cars Factory Exhaust Flap Setting With the Push of a Button
Evm Does Not Engage With Can-bus
No Interference With Any Control Units.
Software Updates Do Not Interfere With the Functionality of the Evm Exhaust Valve Module.
Plug and Play With Original Plugs
No Cutting Wires, No Damage to Factory Cables, Fully Reversible
1 X Exhaust Valve Module
2 X Remote Controls (Button 1 Fully Open, Button 2 Back to Factory)
Wiring Harness (Model Specific)
Installation Manual
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_efm_exhaust_flap_module_001_copy_1be647869aa519da315968c1f0cd3c46bca317d2.jpg)
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_efm_exhaust_flap_module_002_copy_b83d21d35e103a964015b2d2cfd551ec3bceb29b.jpg)
![](https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_efm_exhaust_flap_module_004_1c4dea5fd5efd1163f9708aaec308a249e724441.jpg)
![](https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_efm_exhaust_flap_module_003_866a1ecb911b1007242da6152dc1b5482799a23a.jpg)
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
