Read differential fluid maintenance schedule for 4matic. Maintenance Schedule Table.
I’m trying to do the maintenance on my own for my GLC but I can’t find the actual detailed maintenance schedule for all the components.
The mbusa website just gives you a maintenance schedule booklet that you need to fill out on your own and all the dealership websites just mention “service a” and “service b”.
I have the carfax app and it says that I need a rear differential fluid change at 30k miles but I can’t find this info anywhere else.
My second car has a maintenance schedule that tells you how often you need to replace the air filters, spark plugs, brakes, brake fluid, etc.
P.S: "Rear not read"
Originally Posted by arrow mallow
So I’m trying to do the maintenance for my GLC in my own but I can’t find an actual maintenance schedule for all components.
The mbusa website just gives you a maintenance schedule booklet that you need to fill out on your own and the dealership websites just mentions “service a” and “service b”.
i have the carfax app and it says that I need a rear differential fluid change at 30k miles but I can’t find this info anywhere else.
https://mbworld.org/forums/glc-class...-services.html
Im planning to call MB USA and get the answer
from them on manufacturer required services schedule.
2019 GLC300 4matic
I also have the same question about rear differential oil. Attached is a SERVICE SHEET that I found very helpful. It is the maintenance schedule I found it somewhere on the 'net, maybe here on MB World . At the bottom of the second page it mentions replacing rear axle differential oil @2k and then 30/60/90 etc. But I read this as NOT for the plain GLC300 4matic, engine 274. I read it as being for an AMG version. And secondly, I think there is a transfer case? at the front axle.
