Tire replacement
Old Jan 5, 2020 | 06:59 PM
jamespaul's Avatar
GLC300 4Matic
Tire replacement
Hi,
I am due for tire change, only the front pairs.
Is it possible to just change the fronts?
My total mileage is around 25k miles. A bit disappointed with the stock Pirellis
Old Jan 8, 2020 | 12:41 AM
jamespaul's Avatar
GLC300 4Matic
Was hoping for response on changing the fronts to non run-flats
Old Jan 8, 2020 | 01:02 AM
cyber3d's Avatar
GLC 300
My question is why are your fronts wearing so much faster than the rears that you have to change them without changing the rears too?
Old Jan 8, 2020 | 01:07 AM
jamespaul's Avatar
GLC300 4Matic
No idea, my fronts are gone, but the rears are still in good condition. Both front and rear are stock Pirelli Scorpion Verde tyres
Old Jan 8, 2020 | 03:25 AM
tGs Wraith's Avatar
2020 GLC 300
Isn't that an expected and known issue due to crabbing?
Old Jan 8, 2020 | 04:24 AM
cyber3d's Avatar
GLC 300
In short, yes you can replace only the front pair. But, I would get your alignment checked. Because your fronts should not wear disproportionally from the rears.
And it does not have to be the same model or brand tire. It is not an ideal situation to have mixed tires. But, you can do it. It only becomes a problem if you mix tires left to right.
Old Jan 8, 2020 | 07:53 AM
snrbrtsn's Avatar
2019 Glc 250 AmgLine
Avoid mixing runflats/ non run flats front and back, chassis dynamics will be compromised due to sidewall flex
Old Jan 8, 2020 | 08:04 AM
aweber1nj's Avatar
2020 GLC, 2022 C
There are some other threads in this forum regarding cobbling-together a spare tire setup (if you go to non-run-flats).
Also at least one thread I saw with someone outright replacing the run flats with a regular setup (General Tires, IIRC), but IDK if he/she ever reported back any long term results...you could ask!
Old Jan 8, 2020 | 08:22 AM
Sigp232's Avatar
2021 GLE 450, 2017 GLC 300 4Matic, 2008 FJ Cruiser
Why not spend the extra money and replace all 4 with a quality non run flats and take care of them rotation and balance every year and have a peace of mind for the next 5 years?
Donate the rear tires.
Old Jan 8, 2020 | 07:16 PM
jamespaul's Avatar
GLC300 4Matic
I think I am leaning towards this plan
Old Jan 8, 2020 | 09:06 PM
Takehold's Avatar
GLC 300
+1 - This is what I did. Replaced run flats at 2k with non run flat and have tires stored in the garage. Will have them re-installed when I return lease. Rotate myself every 5-6K. Much better ride overall - Keep them at 31-32 PSI cold and ride is really nice. Never looking back and will do the same with every car I get that comes with RF.
Old Jan 9, 2020 | 05:58 PM
jamespaul's Avatar
GLC300 4Matic
Would you say ride and comfort is completely transformed?
How about the handling?
Old Jan 10, 2020 | 11:27 PM
midesaka's Avatar
2017 E300 Sport, 2017 GLC300 Sport/Night
Just replaced the OEM Pirelli Scorpion Verde run-flats (19") with Goodyear Assurance WeatherReady non-run-flats. So far, ride is very noticeably improved (despite the tire shop setting the pressures at 38/44 F/R) and hydroplaning seems much better. Looking forward to the first road trip with these tires!
Old Jan 11, 2020 | 04:00 AM
S213's Avatar
GLC X253
https://www.puretyre.co.uk/select-ty...des-GLC-15-20/
