Blind Spot Mirror Alert does not lite
Ken
My guess is, if BSA is something you set up in your profile, it may not work unless you open the door and start the car with your WIFE’S key fob. In other words, if you just go to your wife’s profile after opening the driver door and starting it with YOUR fob, the car may be confused. Try using your wife’s fob when you open the driver door and starting the car and see if it works then. I’m an older guy too and need all the help I can get.
Ken
I just hate for her to be going through more motions than she needs to. These are pretty smart cars.
I understand that on different models it works differently (it may be tied to the user's profile, but I don't think any of the MB cars have it tied to a key fob). Unfortunately, on the GLC, you have to select your MBUX profile and also press and hold your seat memory number.
I wish they'd tie them together with a software update. IDK why it's not already. You can set your "Easy Entry/Exit" in the profile, so it obviously can control the seat!
