Replace rear emblem?
Old Feb 20, 2020 | 12:08 PM
Terry Ryan's Avatar
GLC 4Matic
How do I replace this emblem. Is it glued on? I see the three pins, seems they are for alignment, not retainer clips.
The original is still on the car but it is broken.
Thanks everyone,
Terry
Old Feb 20, 2020 | 09:15 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Its probably just three holes in the tail gate and you just push this into them. To remove the broken on, you should be able to pry it off. Im not sure, but that what it looks like Also some people use fishing line to slide under and around the emblem to work it out. Or if its actually broke you can probably just pull it off piece by piece. Good luck.
Old Feb 21, 2020 | 05:07 AM
Terry Ryan's Avatar
GLC 4Matic
Understand, thank you very much.
Old Feb 22, 2020 | 06:16 AM
bad habit's Avatar
A
I don't remember how the GLC is, but if there is any curvature on the base at all, this will not stick! I've seen many reviews on eBay stating that it slowly but surely peels off.
Old Feb 22, 2020 | 10:48 AM
Terry Ryan's Avatar
GLC 4Matic
I got it changed, used small tie wraps under each "spoke" then pulled carefully but firmly. No problem, no remove hatch trim!!!
Old Feb 22, 2020 | 05:10 PM
decorily's Avatar
GLC 300d 4matic
Good that you got sorted. ..thanks for reporting back.
