Active Lane Change Question
this teach-in period, no arrow appears next to theØActive Steering Assist symbol when the turn signal indicator is activated.". I have over 500 miles - Do I need additional miles before it becomes functional? The dealer is "researching" the issue but hasn't been much help.
Thanks,
Mike
Thanks,
Mike
Example, Just press down the blinker to change lane left. The car states in instrument cluster the lane change is to the left. If you intervene via aggressive steering you will negate it. If you use gas or brake and pause distronic, you will negate it.
the car will only do it if the lane keep assist icon is green, hence the need to be over 40 mph. This indicates the car can properly see the lanes. Or at least your car thinks it can see the lanes.
dont bother trying to do it while going up a moderate hill or while in a gradual curve. Doing this either won’t work or the car will try to end your existence depending greatly on your cars mood and/or whether you’ve been paying Mercedes financial services on time
Thanks,
Mike
Mike
Mike
