MB GLC 300e Coupe charging issue
Mercedes-Benz C43 AMG 4MATIC Coupé
Hi guys,
I just got a GLC 300 e Coupe and have som issues with charging it. Charging works fine with 3,7kw and 11kw station, but every time I use w 22kw station the charging won't start. I tried different 22kw stations with different station manufacturers, tried to change the cable. I always use MB type 2 charging cable. The indication on the station says that it is charging, indications on the panel show status bar with the percentage but you can se that the small kw meeter is on 0,0kw and indication above the charging contact does not indicate that car is charging.
Anyone else that have same issue?
