Remove scuff marks from hard plastic in Door
Old Oct 30, 2020 | 12:42 PM
ari_s's Avatar
2017 GLC 300 4Matic
Have been following the forums and all the helpful posts and advice. My first post here asking for advice on my 2017 GLC from the experienced folks and detailers.
I noticed the scuff marks in the plastic trims in the drivers side and I am curious on how to remove them. I use Migeur's Quik Interior Detailer to clean the interior surfaces but it did not make any improvement to these.
Old Oct 31, 2020 | 06:08 AM
bad habit's Avatar
A
There is no way to remove those, we had a thread here a few months back with a very similar issue
Old Oct 31, 2020 | 10:27 AM
Wxchaser's Avatar
2020 GLC 300 SUV 4Matic
I have used Mr. Klean Magic Eraser, then light citrus based spray cleaner. On clean microfiber, apply a very light application of Chemical Guys or other trim gel. and lightly buff till dry.
You may have to apply plastic polish.
Old Oct 31, 2020 | 11:13 PM
ari_s's Avatar
2017 GLC 300 4Matic
Thank you so much for your replies. Would you mind telling me which citrus based spray cleaner you used and also the name of the Chemical Guys trim gel.
Old Nov 1, 2020 | 06:58 AM
Wxchaser's Avatar
Lysol All Purpose Cleaner Lemon or Spic and Span antibacterial cleaner. Any grocery store or car parts place has citrus spray cleaners.
https://www.chemicalguys.com/natural...-dressing.html
You can use sparingly, any plastic trim polish or cleaner.
Old Nov 3, 2020 | 05:19 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
I have seen scuff marks on plastic parts visually removed using a propane torch. I don't think I'd have the ***** to try it but it can be done.
Old Nov 3, 2020 | 06:02 PM
Wxchaser's Avatar
Applying heat does work but suggest that work for the professionals. Deep scratches are hard to eliminate, involves heating, shaving to even scratch, using trim polish, etc.
Old Nov 3, 2020 | 09:05 PM
62bassman's Avatar
18 GLC300 4M
If after trying some cleaning and polishing the scratches are still visible you may check with one of the OEM parts suppliers. Those covers are not very difficult to remove and replace. I did that with my W211. You may want to try some of the larger recycling places that ship used parts, but first determine which years are compatible.
Old Nov 4, 2020 | 04:16 PM
ari_s's Avatar
2017 GLC 300 4Matic
I tried the Mr, Clean Magic Eraser with citrus cleaner diluted option but that did not work for me. I have seen the heat method but not comfortable with trying that on my own
Any other ideas or suggestions are welcome.
