Vibration though the floor and seats
Hi Friend, I need help with My 2016 GLC300 4Matic that vibration coming from underneath the car at freeway speed 70mph up . Vibration is very notable though the floor and seats ( not steering wheel ) any idea what is causes the problem. Thank you in advance
2016 S550 sport, 2018 GLC300, M3, Zo7, 2021 Sierra Denali
When you feel it in your seat it is usually a rear tire, not a front. Check your tire pressure and inpect your tires for damage is first on the list. After that could be a lost wheel weight, and need balancing or could be a bad shock also. Have you hit any potholes lately? Bent rim? Tires also go out of balance as they wear. Might be time to rotate and balance. Good luck
PaulGLC300 (11-19-2020)
I hit potholes once and slightly Bent the wheel but have it fixed by the Dealer . All Tires are new and been balance twice at dealership . But vibration still remain. Car is run out of warranty now
Personally I would find an independent tire shop that has a roadforce balance machine. It will check tire and rim and does a much better job of balancing the tire/rim. I have had this issue and it was crappy tires. Michelins were the fix. I was shocked at how many tires the roadforce balance rejected. Some brands are just terrible. If you did not have this probelm when new I will bet it is tire/rim related. It is possible to be a bad hub/bearing and they can do a hub runout with a dial indicator. They also do this to check your rotors which is also a possibility. 95% of the time it is tires. Good luck
