??? octane vs 91 octane
Old Feb 4, 2021 | 08:07 PM
cbebmb1's Avatar
2021 GLC 300
Smile ??? octane vs 91 octane
What does the label in the fuel filler flap state for minimum octane required? NOT minimum oct recommended. I want to use both minimum octane and/or recommended octane when I choose.
If Mercedes states something less than 91 octane is required, that is what I will go with. It is their engine design and their warranty they have to honor. Please.....no opinions on why you should use only 91 octane and that it's only a few cents more per gallon. That is not the point. Thank you.
Old Feb 4, 2021 | 08:49 PM
superswiss's Avatar
2019 C63CS
Your best bet is to follow the owners manual. Following is what it says for the GLC. Pretty much all engines can take the lowest octane available in the given market if the recommended is temporarily not available. The ECU will simply retard the ignition to avoid knocking, which besides reducing engine power can increase fuel consumption. Other than that with a regular GLC there are no adverse side effects. With the AMG models, they generally advise not to use full throttle and high engine loads until you can fill with the recommended octane level again, but in general, engines are more likely to knock under higher loads, so you may wanna take it more easy when filling with lower grade.
Old Feb 5, 2021 | 09:00 AM
cbebmb1's Avatar
2021 GLC 300
Good input and I thank you sir but, what does the filler flap say for required/recommended octane?
I will find out soon enough. I'm picking up my new 2021 GLC 300 this morning. I will advise what Mercedes states in the filler flap.
Old Feb 5, 2021 | 10:05 AM
abacnus's Avatar
2020 GLC 300 4Matic OffRoad
Congrats! on your new 2021
It is dependent on which part of the world you are living. In Canada, it is 91 or Premium. Should be same as US.
I will take picture when have a chance. Mine is 2020 GLC300.
Old Feb 5, 2021 | 10:20 AM
abacnus's Avatar
Here you go.
btw. The 87/temporary measure is gone in 2020-refreshed-model’s manual
Old Feb 5, 2021 | 10:50 AM
cbebmb1's Avatar
2021 GLC 300
Thank you Sir. I appreciate the picture. I will hence burn 91 min. octane in my my new 2021 if the fuel flap reads the same. The 87/ temrorary measure is still stated in the 2021 operators manual.
Old Feb 5, 2021 | 11:08 AM
abacnus's Avatar
okay, maybe I am mistaken about the manual.
send us some pics of your new ride. It is exciting, isn’t it?
Old Feb 5, 2021 | 08:52 PM
ParjAS's Avatar
19 GLC300 4M (lunar blue/black/black ash aluminum),17 GLE350 4M (selenite grey/ espresso/eucalyptus)
It is best to use 91 octane because the manual says so and 87 octane could degrade the performance of the engine.
