GLC Service Question
Old Mar 14, 2021 | 11:51 PM
Standingoten's Avatar
C450
Hi, I recently got a certified 2017 GLC and I love it.
I am wondering given the CarFax details attached, what service (A or B) should I do next and at what mileage?
Old Mar 15, 2021 | 07:26 PM
DanD.'s Avatar
2018 GLC 4MATIC
I believe starting from 2016 MB decided to go
A and B services every 10K
At the end of the maintenance book, there are a few services by mileage and time:
Every two years regardless of miles you change brake fluid.
I don't remember trany service, I think its 60K
Every 100K coolant
Old Mar 16, 2021 | 08:42 AM
C450
Currently at 66k. Is it safe to assume Service A at 70k miles?
Old Mar 16, 2021 | 02:56 PM
mikapen's Avatar
Your Dealer should have the records for that car. They'll know.
Old Mar 19, 2021 | 02:40 PM
High Technology's Avatar
2020 GLC300 & 2009 SL550 (previously had 1999 CLK / 2006 E500 / 2011 GL450)
I think an A service the next time it tells you, which presumably will be a year or 10k miles from October. They replaced the air filter, so I assume they also did the cabin filter, those two basically are the difference between the A and B services.
MB recommends brake fluid at 2 year intervals, and that would also be due this fall. I will defer to you if you want to follow that schedule as it’s a bit conservative unless you live in a very humid place (brake fluid absorbs water from the air, so it doesn’t wear-out per se, but rather the increased water content is the reason for the change). I’ve tested mine in multiple cars with an electronic tester and it’s never exceeded 1% water content with 3 year change intervals (which is the cadence for our Acura, though BMW and MB recommend 2-year intervals).
