GLC 300 Parking Light
C 230 Kompressor Sport Coupe
I'm sure this has been discussed before but my 2016 GLC 300 has the left running/parking light come on while the ignition is off. One suggestion was that the cause might be that the LCD light might need replacing. Is this right or is it something else? Can this be fixed without going to a repair shop?
Comments and advice to determine the root cause and resolution to this anomaly will be greatly appreciated.
Received 1,605 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
If you have it dialed all the way left, you are telling the left parking lights to come on with the ignition off.
If it's set to "Auto" then you might have a problem.
Are you leaving your indicator on? I haven't tested in my GLC but my VW leaves the relevant side park lights on if you have the indicator stalk in the left/right position when you turn the car off.
