W205/W213/X253/R172 piston cracking - questions on car condition? Cross posted
Old Sep 1, 2021 | 10:05 AM
Camaroguy72's Avatar
2019 GLC300, 2017 E300
Seeing a surge of engine failures/piston cracking and curious on the following for those that have had the issue in the US
M274 engine specific in the :
2015-2018 w205 C300
2017-2019 w213 E300
2016-2019 x253 GLC300
SLC300 R172
If you've had the piston cracking issue (different from the wrist pin loose tolerance issue with the known SB on the early w205's), can you reply with the following?
1) What vehicle year/model and mileage at the time of the issue
2) What's your oil change frequency? The standard 10k mile interval?
3) Is your car subject to severe usage (short trips less than 10 miles frequently, hilly areas, extreme temps)
4) Have you had an induction service done prior to the failure?
5) Have you run any fuel additives prior to the failure?
6) Have you always used top tier fuel at 91 or greater octane?
7) Is your start/stop working normally at the time of failure?
8) Has your engine air filter been changed @50k miles/ prior to the failure?
9) Have your spark plugs been replaced @ 50k miles/prior to failure?
Old Sep 1, 2021 | 02:54 PM
chassis's Avatar
2017 GLE350 4MATIC
Thanks for posting to gather information hopefully to help owners affected by Mercedes-Benz’s pitifully poor reliability. This needs widespread visibility.
Old Sep 2, 2021 | 05:25 PM
mikapen's Avatar
2015-2018 w205 C300
2017-2019 w213 E300
SLC300 R172
I see that you have posted on four forums, and that you have two of the cars that you list.
Have you experienced this problem?
Old Sep 6, 2021 | 12:41 PM
fredc128's Avatar
GLC 300
2015-2018 w205 C300
2017-2019 w213 E300
SLC300 R172
1) What vehicle year/model and mileage at the time of the issue - 2016 GLC 300, 65,000 miles, or about 110,000 km.
2) What's your oil change frequency? The standard 10k mile interval? -Standard interval, at the dealer.
3) Is your car subject to severe usage (short trips less than 10 miles frequently, hilly areas, extreme temps) - Often.
4) Have you had an induction service done prior to the failure? - No.
5) Have you run any fuel additives prior to the failure? - No.
6) Have you always used top tier fuel at 91 or greater octane? - Yes.
7) Is your start/stop working normally at the time of failure? - Yes.
8) Has your engine air filter been changed @50k miles/ prior to the failure? - Yes.
- Yes.
Old Oct 12, 2021 | 12:08 PM
martinsw's Avatar
2017 GLC300
me too!
2015-2018 w205 C300
2017-2019 w213 E300
SLC300 R172
2017 GLC300 bought new, 72,500 mi when failed
2) What's your oil change frequency? The standard 10k mile interval? Yes
3) Is your car subject to severe usage (short trips less than 10 miles frequently, hilly areas, extreme temps). NO
4) Have you had an induction service done prior to the failure? NO
5) Have you run any fuel additives prior to the failure? NO
6) Have you always used top tier fuel at 91 or greater octane? YES, religiously
7) Is your start/stop working normally at the time of failure? Yes
8) Has your engine air filter been changed @50k miles/ prior to the failure? Several times
Yes
Very disappointed in MB engine reliability, seems they know of the problem but no recalls
