GLC replacing tuner control unit
Old Oct 27, 2021 | 09:21 AM
Pablo1513's Avatar
GLC 220 d 4MATIC AMG
Post GLC replacing tuner control unit
Folks
Just had my GLC into dealership to diagnose why I have no radio - display showing 'device unavailable'.
They are claiming it isn't working due to water damage which I find concerning - I believe this is located in the boot / trunk? I'm being quoted £1k to address!!
Part numbers they are citing for replacement are
A2229008911
A222900531780
I'm not sure what each of these are as I can only find details on A222908911 - which seems readily available second hand on ebay.
Is anyone able to provide some help on if I need both parts or only one - if so how easy is it to undertake this replacement myself? Where in the car is this part?
Cheers
Old Nov 16, 2021 | 05:57 AM
SGB's Avatar
SGB
GLC
@Pablo1513 Did you get a fix for the above, as I have the same issue?
Old Nov 16, 2021 | 11:23 AM
RSNovi's Avatar
2014 Mercedes GLK 250 - Polar White
Years ago I used to work for a supplier of OEM radios. One time a vehicle model had an issue with water leaking around the antenna and running along the antenna wire into the radio causing damage.
Old Jul 5, 2022 | 08:33 AM
glcSunny's Avatar
2016 glc
Same issue Radio tuner, any resolutions ? Also quotes £1000+, Basic functionally Radi
Originally Posted by Pablo1513
Folks
Just had my GLC into dealership I to diagnose why I have no radio - display showing 'device unavailable'.
A2229008911
A222900531780
Cheers
Same issue here, quoted £1k for new tuner, 2016 glc. Where is the unit itself? Done expect a basic function to breakdown in 5 yrs, supposed to be an prestige car
Old Jul 5, 2022 | 01:19 PM
SGB's Avatar
SGB
GLC
I ended up going to a Mercedes specialist in Bristol, who was able to source a second hand one for £150, so including fitting cost me £300
There are ones advertised on eBay.
