GLC 300 High Beam Replacement
GLC 300, C300
I replaced the yellow halogen low beams with 6000K LEDs and have been extremely pleased with the improvement. Unfortunately the contrast with the high beams made me purchase LEDs for the high beams. Has anyone replaced these high beams and know the correct way? Can you bend the clips or does it require a special tool?
It's the same as as on the newer GLKs, that don't have the clip, just push the bulb up to release and push down to install it.
https://www.google.com/url?sa=t&sour...SkPe2eRDxdKbr7
What LED bulbs did you get to work? I purchased a set of H7 LED bulbs off Amazon and they did not work. They would stay on for a minute, then flash, then turn off. This was in my 2017 GLC 300 with halogen.
