Mercedes Me Connect
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
Yes. Whoever will be the primary registered user will need to invite others thru their profile. You can't register the same vehicle to two different Mercedes me accounts.
Received 3,833 Likes
2019 C63CS
You can add up to 3 users to each car. They all need their own Mercedes me account and they get their own profile in the car, so you can personalize each user's settings and switch the profile in the car to the correct one for the current driver. There's a setting to bring up the profile selection screen every time the car starts, so the driver can select their profile.
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe kid: 2017 GLC SUV
also @superswiss thank you for your insights on this forum. I note that you don't have a GLC in your forum profile; are you contemplating getting one?
2019 C63CS
what sort of settings are in the profile? I'm sure I could look it up but better coming from a user.
eddieo45 (04-30-2022)
2019 C63CS
No, you can't change the default mode. It'll always start in Comfort, but each profile can have its own individual mode configuration. Like one driver may prefer the steering in Sport and everything else in Comfort, and another driver may prefer the steering in Comfort, but everything else in Sport, so each driver can have their preferred setup for the individual mode. There are outfits such as RJ Automotive and others that offer coding or modules that allow the default mode to be changed, but it's gonna be across all profiles. Some models have a prompt you can enable. If that's enabled, MBUX will ask you for a few seconds if you want to reactivate the last used mode, and if you confirm then it will switch to the last mode, but it doesn't happen automatically.
