2016 GLC without changing gear consult Worksop
I have a red warning “ without changing gear consult Worksop” comes up when I start the vehicle, I press return button on steering wheel goes a way, I can use the car as normal, select drive an reverse, no issue, starting or driving, I then go to park, press the neutral/park button on gear selector sane warning appears, also notice my stop/start function is disabled and auto park brake not functioning I have to manual apply park brake. Are all these faults connected ? I have replace battery as 6 years old and only charging to 12.46 volts, I have also replaced voltage converter in passenger footwell , no change, I’m about to take it to dealership
