About service cost for 5Yr, 6Yr GLC?
I am going to get the 4-Yr Service B for my GLC 300 which is the last year prepaide service I bought when buying my GLC 300. I am wondering if it is better to buy another prepaid service plan for the next 2, 3 or 4 yr-services. What would be the individual price for 5Yr/50K service and 6Yr/60K service respectively? Your suggestions will be appreciated. Thank you!
2016 GLC 250d AMG pack, 2017 GLC Coupe 250d AMG pack , 2002 BMW 330Ci convertible, 2021 BMX X1 sD20i
Not available in Australia.
But year 5 is expensive, auto transmission service, parts incl oil around $1000 Australian. Engine oil, filters, etc all extra as too labour charges @ $300 per hour.
Year 6 service simpler, brake fluid flush and change, fuel filter, oil filter and dust filter.around $800 Australian.
Are brake pads and rotors covered in your plan ? Expect to change them around 40,000Km - full set OEM pads, rotors and sensors around $1900 Australian. Labour extra.
Based on Diesel engine
Additional maintenance work - based on petrol - gasoline engine.
Every 2 years
Replace brake fluid
The specific maintenance interval for your country applies. Observe the notes in the workshop information. In the event of fluid loss, determine cause and perform repair with separate work order.
Vehicles with 4MATIC: the brake test may not exceed 10 seconds on each axle. You could otherwise damage the drive train or the brake system.
PLUS package, invoiced separately.
Additional maintenance work is subject to a separate invoice.
At every Service B
Trailer tow hitch: Check condition and functionality
Every 30,000 miles/3 years
Panorama sliding sunroof: clean and lubricate guide mechanism (where applicable)
Every 50,000 miles/5 years
Replace air-filter
Replace spark plugs
Every 60,000 miles/6 years
Automatic transmission: oil and oil filter change
Transfer case: oil change
Every 120,000 miles/12 years
Replace fuel filter (gasoline engines)
Replace coolant
Every 2 years
Replace brake fluid
At every Service B
Replace air-filter
Replace spark plugs
Replace coolant
sweetnsassy (10-02-2023)
