Master window switch replacement
Old Jun 22, 2022 | 12:31 AM
LenniePaz's Avatar
GLC300
The rear passenger window on my 2019 GLC300 goes down but won't go up. The dealer wants $400 to replace the master window switch but I found an OEM switch for $115. They said it looks like moisture got in the switch and I just got my windows tinted, so I'm guessing they caused the moisture. It looks like it just pops out and the new one goes in. Is it that simple?
Old Jun 22, 2022 | 09:37 AM
MBguy013's Avatar
Veteran: Marine Corps
2021 GLC 300 4Matic
I've removed door panels before, in other vehicles, and most are assemblies that snap into the opening in the door so it should be a simple operation to unplug the old and replace with the new. Sometimes you may be able to do so without taking the door panel off but I'm not sure what's required for the GLC.
Old Jun 22, 2022 | 10:35 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
I did it a couple of times on my 2009 CLK550 (bought the wrong switch once, lol); toughest part was rehanging the door panel correctly (I'd recommend taking some photos of the window's path before you start, window down and also up an inch or so; seems like there are 2-3 slots that all feel right, but only one is).
They diagnosed the issue to be in the master switch and not the one in the rear door?
Old Jun 22, 2022 | 03:35 PM
LenniePaz's Avatar
GLC300
Yes, the rear passenger switch is working fine. I don't think the door panel needs to be removed on my vehicle, but I could be wrong.
Old Jun 26, 2022 | 12:13 AM
m1964's Avatar
2018 GLC, 2012 RX350. Gone: Q5, LR2, XC90
According to this video it just pops out
