Remote start A/C - Heat function
Old Jul 18, 2022 | 07:04 AM
don w's Avatar
C300 W205
2022 GLC300
Is there a way to set the A/C or Heat to start so that you can cool or heat the interior when using the remote start?
I have left the A/C on when leaving the vehicle but to no avail, it isn't running with remote start.
Any info would be appreciated
Old Jul 19, 2022 | 01:04 AM
Kraken29's Avatar
GLC300
Following, same question.
Old Jul 19, 2022 | 11:48 AM
MBguy013's Avatar
Veteran: Marine Corps
2021 GLC 300 4Matic
I haven't looked at the manual but my GLE heats/cools just fine. Well, fine is a relative term. Regardless, I have my HVAC always set to Auto so maybe that is why mine appears to work.
Old Jul 22, 2022 | 12:34 AM
dalazernet's Avatar
2020 GLC300 4MATIC
My 2020 GLC heats and/or cools by leaving the hvac on auto at whatever temperature I want. In fact, while it is running remotely, I believe I can see the temperature in real time in the app and watch it slowly cool down.
Eric
Old Jul 24, 2022 | 04:53 PM
DanD.'s Avatar
2018 GLC 4MATIC
Eric
Agreeg, i have 2018 and it does the same
App shows the temp before and after
Remote start A/C - Heat function-photo460.jpg
Old Jul 28, 2022 | 05:28 AM
edpare's Avatar
2020 GLC300 touring version (but I miss my '93 300SE W140 tank)
My 2020 GLC300 shows the inside temperature when I use the remote start but rthe HVAC does not run until I am in the vehicle. Living in southern Arizona, I need to cool it down before I get in so I use the remote fob to open windows to get some heat out.
I wonder why I can open windows remotely with the fob, but not with Mercedes Me?
I also wonder why I can’t close the windows remotely: idiot proofing?
Old Jul 28, 2022 | 02:09 PM
DanD.'s Avatar
2018 GLC 4MATIC
Im more wondering why car shuts engine when car was remote started and I open a door with key in my hands? So I have to restart the car each time. How about let me push the Start engine button before I can drive.
Old Jul 28, 2022 | 02:48 PM
edpare's Avatar
I think I may know: my Chevy Silverado does run the HVAC when started remotely and does not shut off when door is opened; But, I have to insert key to use the vehicle. This would not be secure in a keyless vehicle like our Mercs, so engine shuts off when vehicle is unlocked.
Old Jul 28, 2022 | 02:54 PM
DanD.'s Avatar
2018 GLC 4MATIC
Hitting Start Engine button is identical to turning on physical key. As car need to identify if key is present. As many other keyless cars I had, it should let me open a door, get in, hit start engine button and drive. If key is not present I would not able to open a door and even if I did car can kill the engine if didn't press Start the engine button and tried to shift to D or R. As many other brands do.
