Door Hinge Clunking Noise
I know this topic has come up previously but, am not able to solve the issue based on the historical advice in older posts. Passenger door on my 2016 GLC is making a clunking sound when the door opens/closes. I've tried lubricant and also tried tightening the little nut below the hinge (based on the advise from the previous posts) but as the nut is already fairly tight am a little bit stuck on what to do next or if i should over tighten it?
Any advice please?
Any advice please?
Received 1,650 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
Try a different lube. Wurth SSK lube has been the German car specified door hinge lube for decades. It has deep creeping properties and doesn't attract dirt.
This is the product and description. It's a staple in my shop.
https://www.eurosportacc.com/product...smart_campaign
2016 GLC 250d AMG pack, 2017 GLC Coupe 250d AMG pack , 2002 BMW 330Ci convertible, 2021 BMX X1 sD20i
HAVE YOU CHECKED LOCK SCREWS/ALIGNMENT IN DOOR ITSELD. Sorry caps lock !!
Also have you checked u shaped lock hook on side door pillar, loose bolts or alignment as well ?
