Internal temp censor location.
Old May 17, 2023 | 11:20 AM
DanD.'s Avatar
2018 GLC 4MATIC
Hi friends,
Does anybody knows where is the censor for internal temp? I think its something wrong with it, as climate control works strange, it cools the car down and then lets internal temp get warm and turns full speed to cool it down again, instead of slowly keep it cool.
Old May 17, 2023 | 08:25 PM
MBguy013's Avatar
Veteran: Marine Corps
2021 GLC 300 4Matic
How do you have the HVAC set? Do you use the automatic setting or manually adjust fan speed? What's the outside temperature and what do you want the inside temp to be?
Old May 17, 2023 | 10:01 PM
DanD.'s Avatar
2018 GLC 4MATIC
All in auto and both sides are in sync. All vents are open.
Outside 80-85 internal set to 72. It gets comfortable and at some point it get too hot and it turns full speed to cool the cabin.
Old May 18, 2023 | 06:52 AM
MBguy013's Avatar
2021 GLC 300 4Matic
I run mine in auto and have never experienced drastic changes, once the cabin has initially cooled down. Unless I change the temp, the fan usually doesn't speed up that much and the temp inside is maintained pretty well. This is in my GLE however and I don't drive the wife's GLC often but it operates just like my GLE.
