Plugging a run flat tire
Old Jul 6, 2023 | 05:32 PM
Bryce1023's Avatar
2024 GLE, 2022 GLC , 2022 GLC
Question Plugging a run flat tire
Had a large nail right in the middle of the tread of the tire. Brought it to a local tire shop and he said that all I needed was a plug. Asked him about getting a patch on the inside of the tire, he assured me that he the plug will last for as long as I keep the tire. In the past I always had the tire repaired from the inside. They are 19 inch Pirelli run flats, anyone have a bad experience with plugging a tire?
Old Jul 6, 2023 | 05:35 PM
chassis's Avatar
2017 GLE350 4MATIC
I plugged a 19 inch BMW runflat with 100% success. Tire lived its normal useful life and then it was replaced together with the other three when the tread was used up.
Old Jul 6, 2023 | 09:07 PM
DanD.'s Avatar
2018 GLC 4MATIC
I got a bolt about 10mm in RFT right in the middle, used plug and tire last for another year till i replaced them all with non RFT.
Old Jul 7, 2023 | 06:18 AM
Teckno's Avatar
2016 GLC 250d AMG pack, 2017 GLC Coupe 250d AMG pack , 2002 BMW 330Ci convertible, 2021 BMX X1 sD20i
I have had run flat MOE tyres plugged with mushroom type plugs by tyre dealers.
Biggest reason why they refuse is two fold, some tyre manuf put a blanket No to avoid lawyer issues. Second more real reason is they have no idea if owner has driven when flat (less than 15psi) as this will severely damage side walls, de-lamination and risk of tyre wall blow out.
If hole is not near side walls and you have not driven on it flat then I would happily plug the tyre if it was my tyre.
Hope this helps.
Old Jul 8, 2023 | 12:11 AM
W205C43PFL's Avatar
Hope this helps.
If you remove the tire from wheel and see the powder stuff, then it means the sidewall is damaged.
I would add a third reason, they want to sell you a tire.
Old Jul 11, 2023 | 10:00 PM
seamus2154's Avatar
2016 S550 sport, 2018 GLC300, M3, Zo7, 2021 Sierra Denali
Just plugged one of our tires. Not one issue.
Old Sep 5, 2023 | 01:33 AM
hceptj's Avatar
GLK350 4Matic
Ditto, got a roofing nail in the middle of the tire, plugged and been driving it for a month but never drove it flat, noticed it losing a few psi every few days, just enough to trip the low tire light.
