Replacement grommet only for windshield washer fluid pump, is it possible?
Old Oct 15, 2023 | 11:09 PM
heathunder's Avatar
mercedes glc300 2018
Woke up with a water puddle right behind the front left tire. It's washer fluid. Took the wheel off and removed the liner and I see dripping from the plastic white piece (pictured, you can see a drip of water).
Can I just buy that plastic piece or some sort of gasket or do I have to replace the entire pump because of it? Pump works great.
It's a 2018 GLC300.
Old Oct 16, 2023 | 12:17 AM
sn202020's Avatar
2017 & 2022 GLC 300 4Matic
If leak because riubber o ring, i woiuld just add some silicone tape or/and caulking on top of the o ring, and see if it stop water.
Old Aug 19, 2024 | 03:44 PM
khalidj's Avatar
GLC
It's a 2018 GLC300.
HELP PLEASE
Does anyone know the paty on the right of the pump with the red and orange wires in it.
Thanks in advance for your help
Old Aug 20, 2024 | 01:19 AM
sn202020's Avatar
Originally Posted by khalidj
HELP PLEASE
Not sure But check this web.
https://www.mbpartsgiant.com/parts-l...iagram=5940355
number 14 level sensor ??
