GLC 350d (2017) 4-matic (engine?) rattle
My main language is Dutch so I'll try my best but there will be faults :-D
I'm here because I don't know what to do anymore.
4 years ago I bought my uncle's 2017 glc coupe 350d 4matic with the V6 OM642 diesel engine.
I had already noticed that there was a rattle when he drove off but didn't pay to much attention to it.
Untill I owned it.. It started to annoy me :-)
It is a rattle that only starts when driving and when the RPM's go around 2000 + (not reproducable stationarry)
It stops when the car is almost at stop. When driving in a city centre with lots of buildings and when the window is down, it is soooo loud :-(
The rattle itself is heard very clearly on the left front wheel and I only can descirbe it when you put some marbles in a bad and shake them.
Like a membrane metal to metal noise.
I started looking for the most obvious things that could cause it. That was no succes.
I took ik to the dealer and they said it was a bad bearing that is holding the propeller shaft into place where it goes thru the engine.
They showed me and it was indeed worn. So they replaced it but that didn't change the rattle.
Mercedes opened up a case but that led to nothing.
Then I took it to another dealer (with lots of mercedes experience) and he said it was the timing chain.
He changed the chain, tensioners, guidance,... and even the balance axle but still the rattle continued.
My last option was that the high pressure fuel pump had an issue so I also replaced this (yesterday). Again... No succes :-(
Can anyone please help me?
PS. the rattle was already there when the car had 40.000 km's and now I'm almost at 100.000km's. Maybe it was there before but I never paid attention when the car was my uncle's.
